East Central, Nebraska | are you wanting to only log coverage or would you like it to turn the seeder on automatically?
difference between finding a simple app rate module and logging coverage, wiring into the seeder manual on/off switch or getting a clutch control module and letting it do it manually or automatically through the incommand. this would also require a swath control unlock on the IC800. both would require similar wiring. if you have the incommand and display cable already your probably most the way there already.
i don't know what an apv 5.2 controller is but maybe it could possibly be interfaced to help the situation, but doubtful. you say no moving parts on the boom but is their a box that is hydraulically or ground driven? | |
